- Jan 10, 2016
https://www.head-fi.org/f/showcase/bs1-experience-ver-earbud.22473/reviews
My take on the Penon BS1.
Cheers.
Cheers.
received my zs5 + silver
DAC = Fiio Q1
OOTB impression
this is 100% subjective
the sibilance is somewhat similar (a bit more actually) compared to my 4in1 (using tennmak upgrade cable, not like there's any difference anyway, but some ppl might bother about it)
bass wise, it indeed has more bass in a sense. but it's a little muddy, only a very little though, should be fine after some brain burn in
while it's indeed punchy it feels like something is like holding it up
and probably i'm the only one that's not so impressed with soundstage?
i feel like its about the same with 4in1
clarity 4in1 still wins
overall i don't think it's better than 4in1,as there's ups and downs.
if you want a bit more bass go for zs5, if you like clarity go for 4in1
now i'm interested how 6in1 sounds like
Shocked at your soundstage comments as to me they have the best soundstage of any iem I own (including the 4in1).
I like the 4in1, but I think the ZS5s dump on them from a great height in clarity, separation, layering, mids, sub bass impact and soundstage.
Like you said though, it's all subjective!
P.s.
Try the larger tips with a shallow fit as they massively improved for me with a good seal.
Well the Blitzwolf Hybrids were a bit 'meh!', certainly nothing to write home about.
Found them...
https://www.aliexpress.com/item/MaG...lgo_pvid=076c2e84-006c-4ad7-8a33-74884ac5cb8d
I've tried dynamic, electrostatic, piezoelectric and planar so now it's just BA and electret to go.
Some of the Final Audio Sonorous headphones use a hybrid DD + BA system.Hmmm, I'm skeptical that BA drivers placed that far away from your ear will make any difference whatsoever. Otherwise, it would be commonplace in full-size headphones wouldn't it?
The other possibility is that description is a typo/erroneous.
That's a ~$60 headphone. You can buy 4 of them for $240!
As far as I know, ADVANCED, formerly ADV.Sound, has even got a 7-driver (iIrc) hybrid over-ear headphone (prototype) with no less than 6 BA drivers.
