Unfortunately amb doesn't offer their boards fully assembled so the ebay version is all the more appealing. On the other hand I've found Chinese kit parts quality to indeed be inferior at times. Resistors can be noisier and caps are notorious for being fake. There are exceptions of course like singer etc. Always tradeoffs. No free lunch.
I see -so you just buy a bare board - then have to assemble the parts yourself.
Well just a simple subbing out of some of the MEIYAN parts might just be easier. The caps are decent -
the big 10,000uf 50V are British Nover's not sure of the specs - but they could be replaced by
Nichicons KG's $7.88 each
http://www.digikey.com/product-detail/en/nichicon/LKG1H103MESCBK/493-13364-ND/1964421
or
Nichicon LLS 3,000hrs life $4.22
http://www.digikey.com/product-detail/en/nichicon/LLS1H103MELB/493-6156-ND/2548862
or UCC low ESR 2,000hr $4.55
http://www.digikey.com/product-detail/en/united-chemi-con/ESMH500VSN103MR45T/565-2677-ND/757890
But these Vishay BC's would probably be the ones I go with: 5000hrs, low impedence, low ESR, decent PSRR reasonable price $9.48each
http://www.digikey.com/product-detail/en/vishay-bc-components/MAL205851103E3/MAL205851103E3-ND/5633230
The small caps could be cheaply replaced by Pannie FM's. As for resistors - Dale's or Vishay's Metal films are the cheap go to's...there's only few.
The white, red and green boxes are likely film caps - those can be replaced by WIMA MKP10's cheaply. Not much else - I'd leave the diodes alone.
