gmplus
- Nov 7, 2016
I have that Zerozone board earmarked for the PART 5 DIY LPS's. I ordered a MEIYAN, so that'll free up my Breeze LPS for a regulator board swap, first will be the LT3042 0.8uv LDO.
Check this offer: http://www.diyinhk.com/shop/accessories0/73-08uv-ultralow-noise-dac-power-supply-regulator-33v5v-1ax2.html
This item includes PCB with Linear Technology newest 0.8uV ultralow noise regulator LT3042 *All SMT component are soldered, thru-hole component are not soldered.
This is the best ultralow noise power supply regulator for Diyer to enjoy, use of decade old 78xx / lm3xx /lt10xx is simply kidding for audiophiles.
This regulator PCB equiped with high quality hybrid choke coil and CRC input filter to remove the common mode noise and differential mode noise from the input and provide the best sound result from time to time.
It is always a mystery for most people why the same DAC usually sound better at night. The reason is the noise pollution through the AC line from all the other equipment in the same room. In the day time, More electronic equipment turn on and there are more pollution.
Feature:
1)Linear Technology 0.8uV ultralow noise LT3042 regulator
2)Two individual 1.5A* 3.3V/5V rail switchable with a jumper easily. Please notes 1.5A is the burst value, please read the bottom notes for output usage larger than 0.5A continuously.
3)Panasonic EEUFC low ESR 5600uF capacitor and the red WIMA film capacitor are sourced from authorized distributor Arrow Electronics directly (guarantee no fake product from China)
