bigshot
But, even though you would probably use it, 24bits would be a complete waste to record acoustic records and machines. The total dynamic range is very small, strongly limited by a high noise floor..
There would be no point to 24 bits if you used electrical transcription. But if you were miking an acoustic phonograph, you might actually need it. As I mentioned before, the machine itself expands the dynamics in the recording. My Victrola produces ear splitting volumes with Caruso records with a very low noise floor. I think that has to do with the way the sound box and mica diaphragm react to energy in certain frequency ranges. In Caruso's high Cs it amplifies it by ringing in a very loud and natural sounding way. In the higher frequencies where surface noise occurs, it attenuates it. The horn also amplifies and has particular resonances. These things effectively expand the dynamic range beyond the level encoded in the grooves of the record.
Is that the different pre-emphasis applied to early records before the RIAA standard was adopted?
This is even before electricity. The same companies that made phonographs also sold records... Victor made Victrollas and sold Victor records, Columbia made machines and records, the same with Brunswick and Edison. Each company had a sound lab whose job it was to design the recording equipment to suit the machines they made, and vice versa. Some companies' records could be only played on their own brand of machine, like Edison and Pathe. You couldn't even play an Edison or Pathe disk on a Victor phonograph.
The music was recorded by performing into a large horn which funneled into a cutting lathe that cut the grooves in a wax master. A clockwork motor ran the lathe. The records were played back with the same process turned around backwards, a clockwork turntable, the needle and soundbox tracked the grooves and funneled the vibrations out through a horn which amplified the sound. The composition and configuration of the soundbox and diaphragm and the shape of the horn and the cutting lathe were all designed to complement each other. Very primitive technology, but very direct- vibrations being made into a physical record then played back the same way. The effect is startlingly present when you hear a really good recording and phonograph.
Here is what a recording session looked like. The horn had a limited range. Everything over ten feet away would fade into nothing. So the band had to crowd around the horn. With an orchestra, they would put musicians on swings suspended from the ceiling so they could get everyone in close enough.
To the left of this photo was the booth with the cutting lathe in it. Note the violin on the right with the horn attached to it. That's called a Stroh Violin.
I used to take a suitcase phono out to the patio of a local Starbucks and play records on weekends. High school kids would come up to me amazed. They couldn't believe there was no power plug or batteries. A lot of them had never even seen a phonograph record before, much less hear one played.
There are aspects to acoustic reproduction that could inform loudspeaker systems. They really understood acoustics and how a room affects the sound of music. Phonograph dealers would suggest putting a phonograph in the corner of a room so the walls and floors would act as extensions to the horn. This lowered bass response and increased volume. The horn made sound extremely directional which projected an aural image of the musician a few feet in front of the machine. It's a really creepy effect. They also recorded dry with no room ambience because they expected the room you were playing the record in to add its own reflections to the sound. Quite different from the way we design sound equipment now.
Once electrical recording with microphones was developed in the early 20s, manufacturers continued to optimize their records for their own brand of machine. Each company had its own compensation curve. A Victor might require a different playback curve than a Columbia. However, it wasn't consistently applied. Something recorded in New York would sound different than something in Chicago. And curves might change from session to session even. Phonograph folks get really good at EQing by ear. There are preamps with presets, but they don't come close to hitting all the variations in playback curves.
