mikaveli06
- Jan 4, 2012
Ill try v5, im ok with not a shuffle all, as long as i can shuffle 1 folder (where i have all my gym songs stored)
Thx
Thx
Hey guys,
I got my X2 4 months ago and it worked great the whole time. I'm new to the whole hi-fi concept so my judgment might not be the best, but i've been enjoying a lot the player. But here's the deal:
Last wednesday a little girl bumped the player that was in my pocket with her head(she was runing, I was distracted). It stopped working immediately, but started playing again after a quick reboot. In the impact, something went a little out of place inside of the player and everytime i'm using it, it may or may not stop working and reboot, deppending on the position that the player is. I tried opening the player to take a look and try to fix it, but the 2 of the screws are striped.
Any tips? Advices?
The obvious would be to remove the 2 defective screws ( with an anti clockwise Drill / Screw Extractor) and see what is wrong inside the Case...
Hey guys,
Any tips? Advices?
What you can hear "rattling" around is actually the buttons.
Don´t think so, if the Player is only 4 months old it should be the new fixed Serial Nr. Version.
I doesn't mean that the buttons are broken, mine makes the same rattling noise when I shake it. It's because the actual button is a little loose/floating. It's nothing to worry about.
,agreed, a simple test you can do is try to hold the mid button while shaking the player. See if you still hear the rattling sound
All I see here is comparison between v5 and v7. What about v6?
I prefer some of the features that v5 misses but v6 has. Any comment about SQ comparison between v6 and v5?
How many of you guys are upgrading to x3 when it realeases. Im pretty sure i am.
