I have this incoming to celebrate the completion of my chemotherapy and being cancer-free! It should be here tomorrow or Monday...can't wait!
Watches - another passion of ours, it seems...post your pics!
kwkarth
Electronics guys... we have our plusses and minuses. With advent of digital everything, we're being phased out
- Sep 30, 2001
Congratulations on all counts!
Originally Posted by gtp /img/forum/go_quote.gif I have this incoming to celebrate the completion of my chemotherapy and being cancer-free! It should be here tomorrow or Monday...can't wait! |
MuZI
- Mar 4, 2004
The Omega Seamaster is one of the most comfortable/sturdy watches I've ever worn.
upstateguy
- Dec 20, 2004
Hi kw
Where are the screws located? My Omega has solid push pins in the band for adjustment, but I don't see any screws??? Are they visible?
USG
Edit for quick and dirty pic of bands.....
Originally Posted by kwkarth /img/forum/go_quote.gif AFIK, the best bands use links held together by screws. A solid pin, unless I'm mistaken, would be held in by some sort of mild adhesive such as locktite. The way my jeweler friend described to me, if I understood him correctly, is to warm up the band with a heat gun, then the pins can be extracted safely. I have several tools to remove and re-insert pins, and all friction fit pins with one exception were split pins. The one exception is with the Tissot T-Touch watches I have. They have a solid pin that is, indeed held in place with something like locktite. I changed the bands on two of them and used an invisibly small drop of krazy glue to keep the pin in place. On all my watches that use screws between the links, (Omega, Breitling, Ernst Benz, Ball,) they're so small in diameter, you might not even realize they're screws until you look at the ends with a loop. I have to use a very, very, very small screwdriver to fit in the slot. |
Hi kw
USG
upstateguy
- Dec 20, 2004
Congrats on all accounts!
USG
USG
kwkarth
- Sep 30, 2001
I see the screw heads in the Rolex band but the screws on my Omegas are just as small as what looks like pins in your picture. Look at it under a magnifier to see if there's a fine slot for screw driver. If it's a solid pin, then you may need to gently heat the band before extracting them. Often the secrws are locktited as well.
Originally Posted by upstateguy /img/forum/go_quote.gif Hi kw Where are the screws located? My Omega has solid push pins in the band for adjustment, but I don't see any screws??? Are they visible? USG Edit for quick and dirty pic of bands..... |
kontai69
- Feb 27, 2005
The Omega bracelets don't use screws but rather pins.
Here is a good tutorial on how to adjust the bracelet on Omegas...
http://mywatchmaker.net/epages/sizingbracelets.htm
Originally Posted by upstateguy /img/forum/go_quote.gif Where are the screws located? My Omega has solid push pins in the band for adjustment, but I don't see any screws??? Are they visible? |
music_man
- Jun 6, 2005
as it turns out the zenith has the same exact type of pins as the omega.
i always thought that if a band was considered high quality it must have screws. this must not be true. since zenith and omega are some of the best watches available(imho).
the thing is they are not split pins like on a $100 watch though. there must be a reason they use the pins. i am sure these companies could have used screws if they wanted to. some other companies use pins like this too. even an old iwc i have(maybe 25 years old).
music_man
music_man
mrarroyo
- Jul 27, 2005
Very happy for you, and best of luck.
kwkarth
- Sep 30, 2001
You are correct, I stand corrected. I was confusing the Planet Ocean bracelet with the Ball Skylab Commemorative bracelet.
Originally Posted by kontai69 /img/forum/go_quote.gif The Omega bracelets don't use screws but rather pins. Here is a good tutorial on how to adjust the bracelet on Omegas... http://mywatchmaker.net/epages/sizingbracelets.htm |
kwkarth
- Sep 30, 2001
My watchmaker straightened me out on this one. The Omega pins have a "detent" inscribed in the pin. The barrel that it rides in has a detent as well and it is the detent in the barrel that captures the detent on the pin.
Originally Posted by music_man /img/forum/go_quote.gif as it turns out the zenith has the same exact type of pins as the omega. i always thought that if a band was considered high quality it must have screws. this must not be true. since zenith and omega are some of the best watches available(imho). the thing is they are not split pins like on a $100 watch though. there must be a reason they use the pins. i am sure these companies could have used screws if they wanted to. some other companies use pins like this too. even an old iwc i have(maybe 25 years old). music_man |
Petyot
Congrats!
Congrats!
Petyot
I like diving watch too... Here are some of my other watches :
And two others I unfortunately had to sell a few month ago to buy another one...
Here is one last picture with my wife's divers watch :
Originally Posted by jcn3 /img/forum/go_quote.gif very nice!! i'm a sucker for a great, unique diving watch. |
- Mar 18, 2002
For what you must have went through, you deserve a lot more than a nice watch. Please stay healthy.
bhd812
- Dec 4, 2003
Yeah people keep posting pics of the sub's and dwellers and seamasters and p/o's...
my wallet hates your guts!
(more pics! more Pics! yeah!!!!!)
