vloh
- Jan 21, 2017
This is my setup. With a topping NX1A.
Hi All,
Did you guys encounter X10 v1.1 hanging? When I play "Michael Jackson - Thriller (VINYL) (NEW MASTERING) YERAYCITO MASTER SERIES - FLAC" My X10 will hang and will not play. None of the buttons, dial and switch can work. I cannot even power off. Pressing the reset button will reset the unit but after power up, it will hang straight away.
The only way to get out this hang loop is to take out the SD card, Reset than put the SD card back in. And dun listen to one of my favourite track.
All other FLAC and MP3 works fine. Does xDuoo read this thread? If they do, hope they will do something to fix the bug.
VL.
Hi All,
VL.
Hello,try to remove the folder album artwork
cue sheets supported/working?
Yes. Supported and working. Just tested.
Thanks. That's nice to have as a workaround for not implemented gapeless playback.
Isn't GR07 sibilant? X10 already has super clear treble, how does it sound?
