ilikepooters
I've tried to forget, mainly by buying tubes to try out in my Lyr, bought 12 pairs so far, costing me a fortune.
I need the miracles to show up just to distract me from the Lyr and the endless tube rolling
I'll be using my Miracles with my Nexus 4 for now, treble is quite rolled off though so i'll need something better eventually, might buy a Sandisk clip+ in the interim.
Mine took just over 10 weeks from THC. Your best bet is to try and forget about them. Mine randomly showed up despite UM Global saying to expect another 3 weeks due to CNY delay. I've been using them now for a couple of weeks and like everyone says 'its well worth the wait'.
I wondered what you guys use as a portable source for your Miracles? One of the main reasons I bought CIEMS was for their portability and isolation. I currently have an iPod Classic 5th Gen, an iPhone 4s and a Colorfly C3. If I really had to lean one way (in terms of sound quality) it would be towards the C3, the sound is slightly more full and the soundstage is greater. However, I HATE the Colorfly for everything else, its UI is so small and in bright light illegible, having to transfer to the Micro SD is a tedious, laborious process, it crashes, it dies....... well you get the point!
Basically how can I get the very most out of my Miracles but still remain portable enough for everyday use. Does anyone use an amp combo with the iPod? If so which? I listen to all genres, so a versatile solution would be best.
