Waking up an old thread...
I am still using the original UM Miracle, which for the record has an official impedance of 15.9 Ohms. According to the experts / theory, all HP amps with less than 2 Ohm output impedance should pair well with this CIEM.
I have recently acquired FiiO M11 Plus Ltd (DAP) and have compared it to my Hifiman HM901S w/ Balanced amp card. I also have the iBasso D7 Sidewinder USB-DAC for my PC. The odd thing is that even though the manufacturers of all three units claims that the (single ended) headphone output has 1 Ohm (or less) of output impedance, the three sources appears to produce quite different frequency responses - at least subjectively. Using the UM Miracle, the FiiO seems to sound the most balanced, while the Hifiman sounds a bit dark (elevated lower mids and bass). The iBasso sounds just awfully dark. Heavy EQ'ing is needed to correct it. In fact, I have stopped using it with the Miracle for this reason.
I expect the stated HO output impedance in these sources must vary more than the specs implies (the FiiO and iBasso just can't both be around 1 Ohm), but which of these three would then have the lowest, the medium and the highest output impedance?
Anyone here who knows this for sure - or have an official impedance curve of the UM Miracle?
