yufeng23
- Oct 24, 2010
Stereo!
A fit issue: both shells have a good seal, but the one in my left ear is little looser and at a closer look it is a bit smaller than the right one, but ears can be different. It doesn't affect the sound quality, but it feels different in both ears and that is a little annoying. I only have them for four days now, so is anyone familiar with this and can anyone tell me if this is a matter of getting used to?
I really don't want te send them back, that's why I need your help first. Thanks!
If you mean the X3 + the Matrix portable, then I really liked it but it was just too dark for the Miracles.Wow! Thanks all for the invaluable input! The aforementioned DAPs are priced too steep for me and I just spent a bomb on the miracles. Are there any other suitable DAPs? Anybody has a take on the Fiio X3?
@lin0003 What's your take of the X3 + DAC?
What if I pair my iPod Classic with an amp/dac?
I pair my Miracles with a the Colorfly C3 and the C&C BH amp and I'm very happy with this set up, it beats my ipod or iphone hands down. Yes, the UI for the Colorfly is pretty shoddy, but you'll forgive this for the sound quality and also the ability to play a whole host of different file types. Might I add the battery life on the Colorfly is immense and also the C&C amp lasts for 80 hours! All for £150 - cant go wrong in my opinion.
Can I ask where did you audition the 3DD and Miracles?
Not really. The miracles are a bit too dark with a neutral source for me already.Haha! I read online that this pairing is really dark! You like a dark sound sig?
Oh yes you need some time to get used to the fit, it was pretty bad for me initially and if this is your first pair of CIEMs it will be even more so uncomfortable for you. Do remember to fit the miracles inside the groove of your Fossa, give it a week or two, if there are still fit issues, you should send it back.
How has the sound changed for you?
Yeah lol. I find that the LCD 3 is just what I like.Hmm.. You must love your treble a lot! For me Miracle is a little bit v shapped.
