Satellite_6
- Feb 12, 2009
I guess you're like most people here - you want really bright sound.
Hmm, it's just that I see so many comments from people saying how detailed the sennheisers are but to me they are somewhat muffled. I will try out some Beyerdynamics though. Thank you for the suggestion
Perhaps I should better explain my situation with them. I find myself using the HD-600's all day and night. They are ultra comfortable. But what I am complaining about is sound quality. It just doesn't sound that sharp. It sounds quite muffled sometimes.
...or a DT880.
That's my recommendation right there. You really cannot go wrong with that.
Since we are on the topic of it anyways, what is the difference between the DT 880s and DT 990s?
What do you consider neutral then?
From the looks of the your other thread, you just wanted the Sennheiser HD6XX smooth sound but with a better balance of midrange to make vocals clearer. It still sounds like you would like the HD598, unless you prefer detail over frequency balance. I don't remember much of the Beyers, but with reports of recessed midrange wouldn't it be the opposite of what you were trying to attain?
However, the HD598 wouldn't have the low end extension of the HD6XX or the Beyers.
Ah! You are experiencing the Sennheiser "veil" as they call it. The HD600 is known to have a more subdued treble response and can sound muffled on some recordings and material. You can make them brighter by removing the foam over the driver magnet but this is risky and I would not advise it. I would give your ears more time to adjust and if you still don't enjoy them you can go to another alternative such as the HD595 (which is not as good but brighter and clearer sounding) or a DT880.
