Acix
- Jul 7, 2008
Originally Posted by Acix /img/forum/go_quote.gif Two glasses full of water, they are both 10 cm tall. Glass one, 3 cm wide. Glass two, 5 cm wide. Which glass have more water? |
Originally Posted by Townyj /img/forum/go_quote.gif Is it true that the 900's are made in Taiwan instead of Germany..?? I just came accross a pair and something in the title said that they are made in Asia.... True or not true..?? |
donunus;4817569 said:hahaha this is pretty funny, everytime I confront acix with a clear explanation, he gives an irrelevant reply.
That is why I asked him if he is really Sarah Palin.
Originally Posted by donunus /img/forum/go_quote.gif Acix, quite the opposite. If you work on a song using the k701 for example, you might get a recording with more bass because you compensated for the 701s lack of bass with the eq. In the end, you will get a bassy recording when played back on the average home system. A bassy headphone used for mastering will get you a less bassy recording since you tend to eq it with less bass... etc.... so its really all about knowing how to predict the results with the monitors you use for mastering. |
Originally Posted by kwkarth /img/forum/go_quote.gif I had the good fortune to listen to the 900s in the Ultrasone booth at the AES Friday and I liked them very much! They merit further listening, which I plan to do. It was VERY, VERY noisy at the show, so critical listening was impossible. As many have said before, there's something about those Ultrasones! Because of the ambient noise, we were listening at a high level and despite that, the highs sounded smooth, but not at all recessed. |
Peter Pinna;4818675 said:Quote:
Heheheeee!!!
Peter,
This question should be addressed to yourself, as you are talking from other people's experience instead of your own. By doing that, it just confuses or irritates others. This is probably why the Monkey is asking you the same question over and over.
But you know what, Peter? I salute you. If you have 609 posts with one pair of 750s, I just can say that you are really a special person.
Originally Posted by Acix /img/forum/go_quote.gif Pros: Anyone who wants the PRO750 should go for the 900. Better pads. Nicer color. S-Logic Plus. Cons: They still sound like the PRO750. And cost almost twice. |
