athenaesword
- Aug 22, 2007
i'll keep that in mind if i ever do have to try out the olives
btw i just noticed you had clear cables on your TF10. are those the stock ones? the ones i saw at a local shop had black cables and a black connector instead of the clear ones i see in your pics
Originally Posted by steviebee /img/forum/go_quote.gif Just go slow with a modelling knife or similar when you're cutting away the Shure core -unlike UE, they're glued in very well...as you'll always cut a hole larger than the original core, UE's fit in easily. |
