pdiddypdler
- Nov 2, 2011
So they're sticking with the 1+2 name? Maybe 1+2 rev2.
More detail than an HD800? Yes please!
Yes Gavin has requested my sending back the demo pair I have. It's actually the high driver after listening to it again that failed on me.
Hopefully the guys in line won't mind too much since it seems now we're dealing with even bigger monster of an IEM to put our grubby hands on. I'm impressed with what the 1+2 rev1 does, so I can't wait until I get to hear the 1+2 rev2.
I think you doing a good deed for those rest in line anyway so the IEMs can be enjoyed to their fullest from the get go (since it is all burnt in).
So rev2 means revision 2? So in fact this is the 3rd incarnation of the IEM? I was under the impression it is the 2nd. Perhaps call it like 1Plus2 V2 (version 2s) to avoid confusion (maybe it's just me).
I think Peter of Double Helix modded his HD800 with solid core silver internal wiring before?
Anyways, it's a nice touch; perhaps not necessarily essential, but a nice touch nonetheless. Tralucent is at least showing attention to detail that they easily could ignore. For example, their cables at least have their own branding on their Y-splits and 3.5mm plugs. They're using right angle pin connectors. Normally, HK/China-based companies just use those silly "UE" connectors, and that's just ugly.
You never know tomscy silver cable does make a noticeable affect on sound to my ears at least. Now imagine them applying silver to all the internal parts and such so there is no weak link in the chain; I feel this will have an even more profound affect on the sound.
I'm not going against you; all I'm saying is that it's not absolutely essential.
Especially if you burn it in for 300h
Sorry couldn't resist.
Hypothetically speaking, if you had 2 units with 2 cables connected to a switch (to easier switch between them, or without it - plug/unplug, if you're going to say it affects sound quality). Would you be willing to tape up the cables so they're indistinguishable to touch/blindfold self and on a volume matched test (if vol matching is required) check whether you're not imagining those, and in fact can't reliably tell the difference (roughly 50/50 selection rate on multiple trials) because you form certain expectations about the sound from the cable price, look and materials used/ vendor claims?
and if you want to argue you're immune to cognitive biases, AES has a nice section on it, where even the snr engineers admit it's unconscious and only blind testing will save you (not literally blind)
or have a hypothetical exercise in logic - if internal wiring or say not unobtainium IEM socket/plug quality is a limiting factor, that would in fact mean that people reporting cable differences are widely overstating impact of cables because of the limiting factor being the socket/plug/wiring.
Man, seriously....Just some things on this forum that people hypothesise or claim as fact ....
what's next, we're going to put thick gold core cables into IEMs for wiring and claim they're amazing?
any comparisons between the fitear 334 and the newly revised 1plus2?
Would be interested in a comparison as well!!
