zachchen1996
- Apr 9, 2012
kind of hoping the revised 1plus2 can surprass the 334 to be the best universal iem so I can save 500$
I have done blind testing with my cables for the IE80s and gone back and forward expensively trying to find a reason to not keep the cable. I can catch the differences quite easily. Fact is when I end up going back to the regular cable I am underwhelmed by the sound. That has not changed. Also with LODs I can go back and forward between silver cable and copper wire and depending on which set up I use it with I may prefer one over the other, synergy. For instance using the T1 with the DX100 on my IE80s I much prefer using the Copper LOD. Using the Silver one gives a metallic and fatiguing sound. Just listening for a couple songs I get fatigued and tired of listening while on the Copper LOD I can listen for hours. Now if you don't believe in the cables having any affect on the sound well good for you. I think otherwise as I've experienced it for myself. I'd love to have stuck to all stock cables and kept things simple. I don't mind saving money and in that regard I am also quite critical. But it does have an impact on the sound for my IEMs and sources and I'm always looking to get that bit of extra sound quality out of my gear .
That is a good point, I guess what I am hoping for is that they will be on about the same tier or level of performance etc. then the 1plus2 will look like a bargain when seen with the 334
Lee, did you listen to 334's from the older batch? Heard that in the new batch of 334's there are changes, including a better extended treble and increased transparency, several people have stated this in the 334 thread. Guess there will need to be a showdown between the revised versions of both.
Saraguis pair is from the newer batch. As I said earlier I didn't find the treble to be lacking at all to my ears. It was even a bit hot up top for my preferences (this was using silicone tips).
I gather from this then that you feel your 1plus2 is not a bright as the current 334's?
Did anyone else get an email concerning the new demo models being delayed a few extra days?
Hey guys,
I've been listening to the 1Plus2 demo unit for a bit now, and on more extended listening, it doesn't sound like a driver actually failed, but just imbalance. I'm not too sure as to why or how it happened, but the manufacturer is suspecting it's because of extended wear due to burn in. I don't agree because I don't burn my gear in continuously 24/7. My burn-in file has rest breaks, and I only leave them burning in over night, and sometimes through school, which comes out to be around 12 hours max per day.
The treble, mids, and bass are all there, but the mids and treble sound very recessed... Imbalance. Tricky, mislead me to believe a driver failed, but nope. Sorry
