Cool not heard of them i'll have a read about them.
They're really nice. Much better suited for portable use than the Pro80's but they're not light years better in pure SQ but still better in my opinion.
Originally Posted by Toothless /img/forum/go_quote.gif
I would suggest you look for a used Kingston HyperX Cloud, same headphone as the pro80.
They should be pretty popular where you live. I bought mine at almost perfect condition for only 50$ with 10 month warranty left.
Hi ! i just did that and i am waiting to receive them.
Let me ask you some questions.
1) which amp are you using to drive them ?
2) have you compared the Kingstons to any other HPs using the same amp ?
Thanks a lot and kind regards
gino
I just bought the HyperX Cloud and I think they sound a little bit too bassy and the vocals could sound brighter. Which frequencies should I eq. to improve this?
I think the Pro80/HyperX Cloud is quite efficient. It sounds loud right out of my laptop realtek onbard soundcard.
Upon plugging it to the Schiit Modi/Magni, the bass turns a bit fuller and tighter at the same volume.
Beside the Cloud, I have a Beyer DT880 250 ohms and a Grado Sr325is and
I gotta say that the Cloud is really close in comparison to those 2 much more expensive cans.
Each of them serves specific genres for me: Cloud for EDM, DT880 for classical, and Sr325 for rock/metal.
Have we found any cheap good over ears in this thread so far? If so give me suggestions.
try to understand what makes Grado HPs so special with rock music
I love them for their quick and forward reproduction of the music. Electric guitars, for example, sound crunchy, lively and extremely addictive through them, which make you feel like you're literally standing on the stage with the musicians. This is what reference, true to the source headphones like the DT880 or HD600 can not deliver.
Is that due to the frequency response? Could I eq. my HyperX Cloud to sound at least more similiar to the Grado sound?
Just to give a second opinion, since the dolphin is quite a lot more expensive at 100$ (right? I have to say my pair lacked build quality. I have a takstar going strong for 3 years but my dolphin didn't last the year and was flimsy from the first day. The bearing hinges that attach the metal hooks (that then attach to the cups) were just awful and with way too much flex and just gave up after less than a year of careful usage.
I woulnd't bother with this since I could just be a 1 in a 100 but since the build quality really oozed "this will happen" and it then happened I feel compelled to write about it. I'd also give the takstars to my ears the overall win. Maybe my dolphins were a majorly faulty unit, but they did come from penonaudio, so they shouldn't be. The bass sounded like it lacked a certain frequency and was somehow just not full, reminds me a bit of HM5s bass, which has a frequency dip, it also reminds me of tests such as golden ears when a part of the bass frequency is removed (lowered). I don't tend to prefer a particularly bassy headphone either, the K550 is what I'd call bang on in bass quantity for me. The dolphins also had harsh highs (maybe a bit similar to the k550 but they arent necessarily emphasized, they just lack refinement somehow), and of course as possibly everyone has mentioned, they don't come close to the soundstage of the takstars. Finally they look much nicer on pictures than in real life.
