DJScope
- Mar 24, 2014
I think the difference is the pads. The Pro 80 has pleather pads and 2050 has velour. The thickness of the foam may be different making your ear lobes touch the inner padding. But for the headband the only difference is the actual design of the material around it. The actual steel headband is identical. I've actually even looked at the DT770 steel band it is also pretty much the exact same thing.
