The amplifier section of the D12 is an inprovement over the D4 for the more difficult to drive phones, as the power supply voltage is greater and there is a greater selection of opamps that work well at the higher voltages plus one can also use single-channel opamps in the D12.. With high-sensitivity IEMs and even with some phones such as the Senn. 600s, the D4 does a very good job and it would likely depend upon the choice of phones and opamps to differentiate between the SQ of the two amps.
My Blackberry can't be within four feet of the device, whereas my iPhone has to be right next to it to create RFI. Of course the Blackberry Bold interferes with virtually every amp or radio it gets near. The thing is a toaster...
Are you using the iPhone 4 with the D12? I recall the D10 had serious RFI issues so curious if iBasso addressed this matter for those looking to connect an iPhone 4 or smartphone.
Any impressions of the iTouch 4th gen-D12 combo compared with the Cowon S9/J3?
I have seen no comparisons yet, but if one is not planning to use the digital inputs of the D12, the P4 would be my preference for use as a basic portable amp.
Does this mean that the D12 and D4 should be almost identical (minus the power supply - which is possibly in the D12's favor, or D4's since it uses a 9v battery?)
I plan to use this mostly with my laptop. I'm bouncing between D12 / D4 and this amp from malaysia that does not have a DAC but from the reviews sounds killer: http://forum.lowyat.net/topic/972446
I will agree, the D12 is a bit of a surprise to me because of the powerful presentation from a lower voltage swing but also due to the increase in transparency and layering. This is stock. When I get the upgrade kit from HiFlight I will take note of that. I find that for me, surprisingly the D12 can drive the HD650's with no problem.
@jamato8- this is good news because I can use my friend's HD600 anytime I'd like and have the chance to really get to know them before deciding whether I want a pair.
I had figured though that the HD600 300ohm power needs would be far from the needs of all of my other phones...happy to hear they could handle your HD650!
Please post which opamps/buffers you like best with HD650. I have a TopKit coming too.
Hi
Can anybody to check what the version of USB built on this apm?
I`m really interested - would be play DAC - 24 bit FLAC?
If USB v. 1.xx it will be impossible
What about a few pieces of hardware that state they get 24/96 from the USB. One costs around 1100. I don't understand how they get more from what is being offered at the output of the USB.
USB can do 24/96 just fine. I've got an M-Audio Transit that does it. On Windows, it needs drivers, as does any USB device that does anything over 16/48. The stock windows drivers don't support anything higher than that. MacOSX supports 24/96 with the stock drivers, depending on which USB receiver chip is in the device.
