trivium911
Thank you, I'm looking forward to get my X3ii immediately. This will be my first hi-res audio device. And all the reviews were PHENOMENAL, not saw a single negative thing about the audio quality.
Yup not really anything negative, word of caution though if you are going to get a 128gb sd card make sure its kingston and sandisk. I bought some cheaper brands (siliconpower) and they were glitching and skipping. Somehow the files went corrupt, as when i tried to transfer them to my new sandisk 128gb cards i had the same issue. I was forced to go back to my hard drive and manually copy everything over again. Everything is glitch free now and sounds spectacular. I do have some 64gb ADATA cards that work well so perhaps the fiio lineup is just picky with the 128gb cards. I have the objective 2 amp which works well with the x3ii and is sort of portable if you get the battery version. You could also get a portable amp like the A5, that way you get the best of both worlds unless you have some really hard drive cans. The A5 should be suitable for the likes of Senn HD600 and 650.
