NCSUZoSo
Did you like the SE210s before the X3K??
So I formatted my SD card to FAT32 from exFAT and my skipping/popping with certain 24/192 or DSD tracks has gone away. It seems even though exFAT does work, FAT32 is definitely what you want to go with. Yes I know it says this in the manual, but for some reason my SD card was not working as well with FAT32 when it came to transfer speeds.
Shure SE425s are great with the X3K
BTW, are we able to take DST and convert that into DFF/DSF? I've never done any converting, but now that we know the X3K can't play DST is there anything we can do about it after the fact?
Has anyone had any skipping issues when playing 192/24 tracks? I am wondering if maybe this is happening because I formatted my SD card to exFAT. It is strange though because everything I put on the SD the first day plays perfectly, but anything I put on in the last 24 hours skips and goes on like a scratched record. Is there a minimum free space we are supposed to leave?
I am reformatting into FAT32 right now, so I will let you guys know if this is the cause of my issues on certain DSD and 24/192 tracks.
Not everything is measurable especially using SPL meter. If we are depending on measurement, there will be very little to no different between Fiio X1 to Fiio X5ii, or even AK240. Our ears, though often subjective, hears more than what common measurement tools can show. Depending too much on measurement tools is not being honest to our ears.
@bestula
Big difference between what you chaps are alluding to and what I was suggesting.
All I'm suggesting is that if you want to compare two items - for what is really audible to the individual, and you want to remove bias ....
- Volume match with an SPL meter
- Compare blind
But this isn't the thread for discussion on it. If you want to discuss it - create a thread over in sound science. I'm sure it will be an enlightening topic
Well I CAN measure my love of music......
It's measured by the funds in my wallet.
It is possible to convert DST files to DSD.
If you have an iso image, just use iso2dsd (http://www.audiocircle.com/index.php?topic=129913.0). this is a crossplattform java program. very easy to use and effective.
but if your files are DST dff/dsf you should use DST2DSD (http://www.nakata-jp.org/computer/freesoft/DST2DSD/index.html). this is windows only, but you can always run it in an emulator. The site is in japanese, but there is a download link on the bottom of the site.
hope that helped.
On another note, what transfer speeds do you all get when writing to the SD card while inserted into the X3K?
