CosmicHolyGhost
Exhaustively burning holes in his wallet
- Jun 10, 2013
If this is equipped with a good DAC, there is no reason not to support Fiio and just buy one for amping.
Atleast we're all on the same page.... Otg is useless. HO and LO w/ Expandable memory, more than likely microsd to save space. No built in memory, cheapo screen, no wall plug, but a good dac. Everything else is not as important.
+1 But let's not push the things too far with a too cheap screen. Have you seen a budget non-smart and non-touchscreen phone recently? I have two backup phones - Nokias with 2 and 2.4 inch screens and they are ridiculously bad with like a 10-degree viewing angle and you can't see almost anything in sunlight or any bright light and they aren't even the cheapest Nokia models.
I guess with all the higher-end phones in the past few years when most people think of a cheap screen they imagine that it just has low resolution and not the greatest contrast but there are a lot of bad screens out there and you wouldn't want anything like them on any of your devices.
I could care less about viewing angle or resolution, I can use my other hand to block the sun if need be.... A good dac.
Well, of course I want a good DAC - that is a given but you haven't seen how bad a screen can be. Shield it with hand - yeah, and go find a shade otherwise you still won't see anything.
Since we are all crazy and worried at the same time about the FiiO X1 DAC quality, why not sacrifice the amp... So no built in amp since majority of us will be bypassing it and you can get the E6 for less than $30 these days. So make the FiiO X1 $70 maybe? xD
Interesting idea, but:
NOOOOOO!
The most attractive aspects (after SQ) of DAP's are that they are convenient and portable.
Adding ,and carrying extra kit such as amplifiers just isn't my bag.
Please, I need a built-in amp.
All I need it to drive is multi driver c/iem's, not Stax or ortho's, so the amp section could be fairly small, but still....
Maybe the X1 is just as thin as iNano 3rd? Then adding an external amp still wouldn't be bulky... XD
