Joe Bloggs
Sponsor: HiByMember of the Trade: EFO Technologies Co, YanYin TechnologyHis Porta Corda walked the Green Mile
Brooko,
No point in my going through an ABX test as you yourself noted that my results would not be sufficient to convince you.
No problem
Can I also infer from the above that you haven't performed a properly volume matched abx test - using tools like foobar's abx comparator, and taking a high-res master, and resampling same file to redbook and comparing?
You don't need to answer - I'm just curious if you've ever actually done one?
Ok guys--a drawn-out debate on the possible benefits of high-rez doesn't really belong to a product thread for a player that supports everything from mp3s to 24/192 Just load your player up with whatever you deem quality enough and be done with it. It doesn't matter which side of the debate I stand on
FYI the X1 and X5 have gradual lowpass filters that kick in above 20kHz, thus the FR specced for +/-1dB or so is up to 20kHz. It is however by no means brickwall limited to that. The rolloff helps alleviate IMD and RF interference so should result in an improvement in SQ in theory. h34r:
Stay updated on HiBy at their facebook, website or email (icons below).
Stay updated on HiBy at their sponsor profile on Head-Fi.
