Type | Where used | Configuration | Notes |
2.5mm (3/32") stereo phone (TRS) | Common on some mobile phones. | Tip: Left signal
Ring: Right signal
Sleeve: Ground
3.5mm (1/8") stereo phone (TRS) | Standard stereo connector for headphones to small and portable devices | Tip: Left signal
Ring: Right signal
Sleeve: Ground
| Most popular stereo connector for headphones currently, ubiquitous in portable devices |
3.5mm (1/8") stereo phone (TRRS) | Standard stereo connector for headsets to mobile phones: iPhones and many other Apple iOS devices, recent Samsung, Blackberry, Nokia, and HTC Android phones. | Tip: Left signal
Ring 1: Right signal
Ring 2: Ground
Sleeve: Microphone
| Increasingly popular for mobile phones. Some headphone amps are compatible with this pin arrangement, others are not.
Ring 1 is closer to the Tip, Ring 2 is closer to the Sleeve.
Compared to the standard TRS connector, the ground is moved from Sleeve to Ring 2, and the Sleeve is used for mic and control signals.
6.5mm (1/4") stereo phone (TRS) | Standard stereo connector for full-sized headphones for use with desktop or console amplifiers | Tip: Left signal
Ring: Right signal
Sleeve: Ground
| Formerly the most popular stereo connector for headphones, still common for home systems |
3-pin XLR | Used in pairs for balanced console/desktop amps | One connector for each channel:
Pin 1: Chassis ground (cable shield)
Pin 2: Channel positive (+)
Pin 3: Channel negative (-)
Shell: ?
| The pins are numbered on the bodies of the plug and socket.
4-pin XLR | Used singly for balanced console/desktop amps | Pin 1: Left positive (+)
Pin 2: Left negative (-)
Pin 3: Right positive (+)
Pin 4: Right negative (-)
Shell: ?
There is no official pinout standard, but this is the normal arrangement for the cables shipped with AKG K1000 and HiFiMAN orthodynamic headphones.
4-pin mini-XLR | Used occasionally for line extensions | Pin 1: Left positive (+)
Shell: ?
There is no official pinout standard; convention is to replicate the full-size 4-pin XLR.
Auto-IRIS | Balanced connector on RSA balanced amplifiers | Pin 1: Left positive (+)
Pin 2: Right positive (+)
Pin 3: Left negative (-)
| Used for the Ray Samuels Audio balanced portable amps: The Protector and SR-71B.
Outside of audio, this is commonly used to connect controller circuits for video camera lenses.
HIROSE HR10A-7R-6 | Balanced connector on iBasso balanced amplifiers
HIROSE HR10A-7R-6P is the male connector
HIROSE HR10A-7R-6S is the female connector
| Pin 1: Right ground
Pin 3: Right negative (-)
Pin 4: Left ground
Pin 5: Left Positive (+)
Pin 6: Left negative (-)
| Pins 1 & 4 are not used for headphones.
Pins 1 & 4 are used only for device interconnects (eg, DAC -> amp)
Outside of audio, this is commonly used as a video connector.
Stax low-bias 6-pin | for non-Pro products. | Pin 1: Bias
Pin 2: Right positive (+) (Front stator)
Pin 3: Left Positive (+) (Front stator)
Pin 4: Left negative (-) (Back stator)
Pin 5: Right negative (-) (Back stator)
Pin 6: Bias
| High-bias Stax headphones are similar, except for the bias configuration.
Source and diagram: Wikiphonia
Stax high-bias 5-pin | | Pin 1: Bias
| Similar to low-bias Stax connector. High-bias headphones can connect to low-bias drivers, but not vice versa.
The following connectors are obscure, little-used, or obsolete. | | | |
3.5mm (1/8") stereo phone (TRRS) | Rare: Used by HiFiMAN as a headphone connector for its HM-801 Balanced Amp Module. | Pinout pattern for this connector is needed. | This uses a conventional connector in a nonconventional way, so be wary about randomly plugging things in. |
Koss electrostatic connector | Used only by the Koss ESP/950 headphone and companion E/90 amplifier. | Pin 1: Right negative (-) (Back stator)
Pin 2: Left negative (-) (Back stator)
Pin 3: Right positive (+) (Front stator)
Pin 4: Bias
Pin 5: Left Positive (+) (Front stator)
| Some users build adaptors to connect the ESP/950 to high bias Stax-compatible drivers, due to the similar voltages (Koss: 600 V; Stax: 580 V).
Source, diagram and commentary: Wikiphonia
3-pin XLR | Rare: Used singly for unbalanced console/desktop amps, eg the Yamamoto HA-02 | One connector for both channels.
No connection standard: Check documentation for the device you're hooking up.
The primary advantage over a TRS phone plug is the minimized potential to short circuit when the plug is not fully inserted.
5-pin "Domino" (DIN 45620) | Obsolete: used for a while in the 1960s-1970s on equipment manufactured in Europe. | Building an adaptor is discussed in Philips Electret N6325 and "Domino" DIN output | Unless preserving the original equipment intact is a requirement, most recommendations are to snip the DIN plug off and attach a common phone or XLR connector. |
