T.R.A.N.C.E.
- Mar 24, 2010
HibyMusic reportedly could read contents in Aurender Flow USB DAC via USb connection from a phone.
If it can read from Aurendrr Flow, it should read from Teac DAC too.
If a PC can recognize P90SD as an storage device and show its microSD content, HibyMusic will do the same.
Yes PC can read P90SD, shows up as removable drive. I'm not using P90SD with any other device, just been using P90SD by itself with micro sd.
Also did you know the PCM1795 uses the same amount of power as desktop ESS9018! No wonder P90SD has short battery life.
