UnityIsPower
If I didn't, that would be a very(very) bad thing indeed given they were defective.
^ HAHAHAHAHAHA ......
Edit: Might have defective pair, waiting for replacement unit.
Yeah mate, even when I lifted the volume on the KC06, they didn't sound painful. It's hard to be sure but I also want to say the sense of clarity was a match if not better on the KC06. I'll try to ask my niece for her pair to compare.
I don't think the GR07 BE is widely considered a "basshead" iem. To me, it's lacking quantity when I really want to get moving but it works so dam well with so dam much kind of deal. It does bass justice on music that needs that low end presence and I consider it my lower limit for quantity in most cases. Something like the H3 would be more basshead territory.
Now you might say I'm a basshead but take into consideration I would end up using a more balance iem like my BE more then the "basshead" phone number two I've been searching for. I listen to too much music to want my low end lifted that much all the time. It might be my lower limit but dam can that limit be done well. Ergo, GR07 BE is stiff competition from inception to supposed discontinuation, impressive in my eyes and ears. Don't forget its cost...
KC06 comes first before altones? Is this purely because of the hot highs? I am a bit sensitive to highs though I recently discovered this as I couldn't stand the highs of jh13fr and ditas when I auditioned them.
Wow - definite basshead huh? I have Lorde's album, and could never imagine wanting more bass than the Altone200 delivers with this album.
Thanks for the impressions - it'll be great seeing some more POV. I'd be really interested to see if your impressions change after some more time with them. I'd suggest (if you do choose to review them in depth), that you spend at least a full day with them (no back and forth swapping) to give your ears a chance to adjust to the new sound signature. Then do the A/Bs against the VSonic.
On the appearance comments:
- Mine arrived with no residue or film, but I have another pair coming as well (I paid for them) - so will check those to see if there is any. The build quality as far as machining goes on my first pair is excellent.
- The "A" in Altone (on the body) is supposed to be a split "A" (there is a gap at the top). It is part of the styling of the text. Nothing wrong with the quality of the lettering - you may just not like the font.
Anyway - looking forward to hearing more impressions later. It has solved one thing for me - the VSonic GR07 BE is definitely off my list of IEMs to try . Out of curiousity - what other audio gear do you have, and besides the GR07 - what else is your "go to"?
