He seems to be using regular Belden wire, which is pretty standard high-quality cabling, not an esoteric multi-thousand dollar boutique audiophile brand.A power cable makes no difference lol, let alone on something so low powered… Open your amp up if you want to see the “boutique” normal wiring being used inside your amps or hell rip down your dry wall and check out the exotic wire running through your walls and switch board
Stax SR-X9000
- Thread starter HBen
phil3607
What about RFI? Or doesn’t that exist either? If you want to start a debate about cables why not head over to a cable forum where they may at least give a damn about your opinionsA power cable makes no difference lol, let alone on something so low powered… Open your amp up if you want to see the “boutique” normal wiring being used inside your amps or hell rip down your dry wall and check out the exotic wire running through your walls and switch board
Aspirant Audiophile
...wouldn't doing so drown an attempt at actual discussion with groupspeak?What about RFI? Or doesn’t that exist either? If you want to start a debate about cables why not head over to a cable forum where they may at least give a damn about your opinions
I appreciate when forum posters express reasonably articulate contrarian views about components which may or may not synergise with the main product-of-discussion. If every hifi component were discussed in a separate forum (which headfi and all hifi audio forums obviously prefer), I think the main beneficiaries would be not the forum participants, but rather the manufacturers of the product in question.
I also insert a DC blocker in the mains supplyIm using srm 700s, which I guess is the latest version of the 717. I find it much better in direct mode ( by-passing the in built in volume control), so if you’ve got a good pre or quality digital attenuation, I’d use that. I also made the mistake of running it out of a extension socket (for a time, needs must) but getting it powered directly from the wall socket with a diy 30 amp mains lead (Belden) made a big difference, which is no surprise really!
xshen79
- Apr 3, 2012
Thanks for sharing! Megatron does better than carbon that means on synergy with x9000?
We're splitting hairs at this particular mountain peak (I still love Carbon with x9000, in spite of them having "bad" synergy), but I believe the word you're searching for is "Megatron
aokman
Most noise is already in your conductor wires and introduced from other devices on the same wire runs back feeding into your house circuits. That is why any self respecting devices have input filters, isolation transformers and power supply regulation… Likewise the wires running up your walls and into the roof and even street over long runs provide far more potential for noise injection.What about RFI? Or doesn’t that exist either? If you want to start a debate about cables why not head over to a cable forum where they may at least give a damn about your opinions
Im not trying to derail but please don’t start this power cord stuff lol. An extension lead vs the wiring in your walls is basically the same other than wiring gauge.
But hey don’t listen to me, listen to the people who have a vested interest to sell you stuff, I'm sure they’re completely unbiased…
If your device already has an input transformer, then no DC can ever pass through it…
phil3607
You’re getting your knickers in a complete twist over this aokman. Go back and reread my posts and you should hopefully see that the point was to get rid of a fused extension block which I was having to use as supplied power cable didn’t reach the plug. How you can accuse me of starting a power cable debate and pandering to the whims of AudioQuest and the like when I bought cheap Belden mains cable and plugs and made up my own (that’s what DIY means) is just ridiculous. You started this debate, but just to be clear on the RFI point which you seem to have missed, the reason the cables are screened is to reduce the “emission” of RFI into the sensitive analogue and digital signal cables running in close proximity behind your equipment, nothing at all to do with RFI already on the line which is dealt with in the equipment. Now don’t get me wrong, I’m no fan of overpriced audiophile cables, I make up all my own (DIY) cheap and effective so hopefully we can at least agree on that.Most noise is already in your conductor wires and introduced from other devices on the same wire runs back feeding into your house circuits. That is why any self respecting devices have input filters, isolation transformers and power supply regulation… Likewise the wires running up your walls and into the roof and even street over long runs provide far more potential for noise injection.
xshen79
- Apr 3, 2012
Easy guys, this is x9000 threads. Power cable thing is way beyond what these headphones can handle
- Aug 15, 2011
+1Easy guys, this is x9000 threads. Power cable thing is way beyond what these headphones can handle
[Mod hat on]
@xshen79 is right. Please stick to the SR-X9000 topic.
[/Mod hat off]
Magnifico
- Jan 17, 2017
Hello friends,
I have sold BHSE and bought T8000 for my X9000.
I have never heard Carbon/Energon/Novem/T2 and other top level energizers, that you, guys, talk here about, but T8000 with X9000 was better for me than BHSE, but the difference is pretty small.
xshen79
- Apr 3, 2012
Thanks for sharing this! I believe you must have tried 700t/700s when buying t8000?Hello friends,
Hope there could be a end-game tier amp at BHSE price point for x9000...
Yes, there is!
Stay updated on HeadAmp at their sponsor profile on Head-Fi.
Don't think so - as far as I can tell, the serial #s are sequential starting with 1000. It's been almost 3 years since the X9000 announcement, and they make a little more than 1 pair per dayThanks – good to know!
xshen79
- Apr 3, 2012
Cayman Jr.? Haha!Yes, there is!
