Thank! Interesting, what Is your experience with the Burson OpAmps? How did the Phonitor improve?
I am a long time owner of the Phonitor & pretty happy with it but nevertheless curious as to how the upgrade could improve.
Did you do this yourself or have someone perform the OPAmp change?
Thanks!
I replaced the stock OpAmps with the Burson's my self. It's really simple to do if you get the DIP8 socket version of the Burson OpAmps (literally plug and play)
One of these days I might get around to replacing the capacitors and volume pot with higher grade components - but that's a lot more work and requires good soldering skilz.
The stock Phonitor sounds like a very nice piece of audio gear - Quite like-able really.
Modded with the Burson's the Phonitor becomes "live" - as in it sounds more transparent, open and airy, with tighter more realistic bass.
Voices sound more realistic and instrument separation improves. The Burson's sound good out of the gate, but they do improve nicely over the first 25-30hrs or so of use.
I also use a full set of Stefan AudioArt Endorphin Series cables with my Phonitor and HD800 (Power cable, XLR interconnects, headphone cable) and together with the Burson OpAmp upgrade, this is just a wickedly good combination!
I ordered Burson for my Auditor 2 days ago
Excellent, I don't think you will be disappointed
The Burson's are one of the very best OpAmps I've heard period, and are a very nice upgrade for the Phonitor and Auditor.
