BenKatz
nice to see someone who has the XZ man. How is the overall headphone jack quality coming out of the XZ? Also, I reckon that quality gain is due to the LDAC which does wonders it seems to work doesnt it? it comes close to wired as far as I can tell and its a real big advantage if you own an xperia phone. Basically since LDAC is ahead of other bluetooth it makes buying an LDAC headphone a no brainer for xperia users over other brands.
generally would you recommend the mdr1a or the 1000x?
Well first off the dac/amp combo in the XZ is superior to the one in the 1000x. I can tell you that simply because connecting the headphones via cable sounds fuller (though not by much) than via Bluetooth (LDAC).
As far as 1A vs 1000x. Depends. For portability 1000x. They sound clearer, more precise and louder, via cable or wireless, than the 1A when used with a portable player. Plus they isolate a million times better (NC). For home use with a dedicated dac/amp combo, the 1A will sound better.
