jpr703
- Sep 24, 2004
Go with pink, the wife will love it!
Originally Posted by Sleestack Pink isn't going to happen. I'm narrowing it down to black or chrome. More importantly, what features would you incorporate into a reference, custom, cost-no-object SS amp?.... other than tubes, you tube freaks. |
Originally Posted by sacd lover I especially like having a loop out so you can drive both headphone amps off your best source. I would add preamp outputs on the amp too. The cost would not be much more and then you would have a state of the art SS preamp too. If you are going to switch between various headphones I would get a high/ low gain switch .... and this is a good option to have if the amp will be doing preamp duty so you can get a good gain match with your power amp. Stepped attenuators for precise channel matching would be helpful when running balanced .... especially if you are going to have dual volume controls. A remote for volume and/ or input switching would be very cool too. |
Originally Posted by tom hankins I like the silver for the SS, and you already have the black for the tubed. I agree with the earlier poster that the silver really brings the look of the corners out. |
