sygyzy
- Oct 16, 2003
Where do the aftermarket cable companies get their plugs from? I can't imagine this greay mystery is still not solved.
Originally posted by Karlosak I don't want to ruin the delight but there is a problem with the dimension of the "outer part" of the connector - it is narrower than the original Senn. But if the "inner part" is right and the distance between plugs is correct then it will fit, but not firmly (better said, it will be a bit loose connection). |
Originally posted by sygyzy Where do the aftermarket cable companies get their plugs from? I can't imagine this greay mystery is still not solved. |
Originally posted by cavedave Hey guys I posted on another part on the site and nobody really cared they are to busy buying the more higher end HD 650 cables What I did was get a grado 325 cable Grado sent me one for 35$ and spliced the ends of my HD650 cable on to it.I also got a cable from headroom HD 600 and made one from a Grado 125 cable both of these have the 1/4 inch plug and sound very very good I had the cardas for a year and these to me sound way better invest about 65$ and a little time you will not be sorry.Just thought someone might want to know. |
