floydfan33
- May 25, 2010
Here's mine.
Here's mine.
Just got mine yesterday.
Noticed the typical 6k peak isn't as significant here.
Me and a buddy recently compared 2 HD800's, one with a frequency chart showing a huge bump at 6,000Hz (his) and the other one showing a relatively flat bump at 6,000Hz (mine) and put them through a sibilance torture test. Result: we could not discern any difference between the two.
I would like to make a clarification upon these well-put comments. Including me, perhaps no one here thinks of selling their HD800s only based on this data. Any such difference would be indeed too subtle, if not inexistent -- I still acknowledge the possibility of the latter. Therefore it is untenable to argue that these very minor differences do dramatically change the sound signature or the overall characteristic of the HD800s. However, it is not less noteworthy that what is frequently called 'harshness' on the upper-mids is also something subtle for the HD800s -- it does not always surface, it is not always felt in any HD800s. The common wisdom is rightly to have faith in Sennheiser about the overall standard quality, but it is also understandable for the same reason that each graph is carefully made by Sennheiser to be indicative of some little nuances. Most of our graphs have very similar curves between 20hz-1kHz (almost exactly the same if you check them carefully), and then they somehow begin to fluctuate after it. Both the consistencies and changes suggest that the measurements are carefully made, and some nuances are caught only at certain points. This is of course purely technical up to here. A useful method to seek these nuances by ear is to focus on 6kHzs relative position to the other frequency ranges within each HD800s. For instance, I was not surprised at all when I saw a 4kHz prominence on my HD800s instead of a 6kHz peak, because I never feel a 6kHz peak on the midrange, but instead a nebulous 3-4 kHz echo. With regard to any possible subtleties, what one feels after long sessions of listening matter a lot. This is why I think long-periods of carefree listening are not less helpful than extremely conscious blind tests.
It could be that one set has worn earpads causing the 'phone to sit closer to your ears, making it louder and more fuller in sound.
I have currently two HD800's in my posession. One is serial 16XXX, the other is 28XXX serial. They sound pretty different for identical headphones. The 28XXX is a bit fatter, bolder, bassier, mids more up front - while it is loosing some of that exceptional soundstage wideness in comparison to the 16XXX. The 28XXX sounds louder too when comparing them side by side I have to adjust the volume to feel they are leveled. Both are good, and actually - if you are a headphone freak, there is no doubt that you can justify owning them both - even though they still sound like HD800. There is more variation between these two pairs than what I get with different amplifiers. I can not claim that all 16XXX and 28XXX will sound like mine - but if this is just within standard tolerance, I'd be really surprised. My guess is that Sennheiser adjusted the damping in the driver unit just a tad, to get a less clinical sound. Which is what users have been asking them to do - basically.
