Chinafbi
- Jan 3, 2012
I just got the hd650 HP. which would sound better? fiio e09k w/ e17 or the magni and modi? I care most is the sound. Thanks
The higher mu is also going to translate into higher gain which may or may not be an issue for you depending on your source, attenuator an
whether or not you're comfortable padding your pot. (see http://www.goldpt.com/mods.html)
Hi again.
Thought I would follow on that I have a 23 Step Ladder Attenuator on its way and some 270K, 0.25W resistors arrived yesterday to temper down the gain a little if needed.
I would be very interested to hear how your modded up Crack compares with your Mainline?
Nice! I'll be interested to hear your impressions on how the new attenuator sounds! 270k seems like it might be a little high to run in series with the input though. If you take a look at the tables on the goldpoint site (http://www.goldpt.com/mods.html), and depending on the value of your new attenuator, you can pick R1 and R2 values that will preserve the amp's input impedance while reducing the volume by a certain number of db's. For instance, if you want -20db, with a 100k pot, each channel should have a 82.5k ohm resistor inserted between the input and pot, and also a 10k ohm resistor shunting from the pot input to pot ground.
With respect to a crack vs. mainline comparison, my general comments are here (see post 46): http://www.head-fi.org/t/662240/mainline-new-bottlehead-premium-headphone-amp/45 . All my mainline listening to date has been with hd800's though, so my comments may or may not translate perfectly to hd650's. I'll have to make a point of spending some time with that pairing sometime soon. I also have some AD's on order that should be shipping out in the next couple weeks that I'm eager to hear with the mainline.
I tried that tube with 5998 and GEC 6AS7 to drive HD700/800 but preferred Mullard E80CC instead, also Sylvania 8514 pairs great with 5998, have a pair for sale if anyone interested
Mazda CIFTE 12AU7, damn can't use on the Lyr huh?
