gibosi
- Oct 18, 2012
I got the reply from the eBay seller. Here was his explanation:
"Here's a site that talks about the tube codes. http://www.audiotubes.com/teledate.htm perhaps you can determine if they are from different years or maybe one was made in Berlin and the other made at the Ulm factory. When I mentioned closely matched in the listing, I was referring to the Gm readings taken with my tube tester. One might be a mm taller, but they have the same getters and construction looks the same. They could have been made at the same factory but on different days by different people. So yes, they are both 6DJ8 tubes and they are both Telefunken manufactured as evidenced by the diamond in the base of the tube."
Many vendors take this position: If tubes look the same and measure the same, they are a "matched pair." It is important to remember that most vendors have a rather limited knowledge of the tubes they sell. In fact, many do not really know what it is they have. Again, if these tubes were manufactured in different factories and/or at different times, then they are not what I could call a "matched pair." On the other hand, if these tubes sound great, and didn't cost an arm and leg, it is probably best to just relax and enjoy them.
But in the future, when shopping for "matched pairs", one should always be a little suspicious, as the phrase typically means no more than this vendor states. Again, unless they were manufactured in the same factory, at the same time (or in the case of Philips, have the same change code), and have closely matched measurements, they are not a true matched pair.
If I cannot see the production codes in their photos, I always ask them to give them to me. And if possible, I ask for a picture, so I can see the the codes myself. And if the vendor refuses or ignores me, I pass.
