goodvibes
- Dec 28, 2009
Things like a zoom H2n is under $200 and actually records. May surprise you. http://www.amazon.com/Zoom-H2N-H2n-Handy-Recorder/dp/B005CQ2ZY6
Guys, I am having problems with my RB'ed Clip+. When I connect it to my computer (Win 7 64bit), my computer doesn't recognize it so I can't see the folders thus I can't change the songs in it. How can I restore it? I am getting fed up listening to the same micro sd card all the time.
I can charge it though, it is just it doesn't appear in Computer, next to the other removable storage devices.
don't know why, but the easy way around this is to use a card reader. they cost nothing and worst case scenarion will let you upload music on your card faster.
Have you tried booting into the Sansa firmware and then connecting it to your computer? Sometimes when you connect a RB'd Clip+ it still tries to keep the RB firmware up which doesn't connect to the computer all the time (or not at all, but for some reason I remember being able to at one point)
Hi guys,
Loved my clip+ but it was just so beat up from being used to much that I decided to give the clip zip a try, Ive heard a lot about how they are basically the same thing despite the screen - this is rather true.
Although my clip zip feels newer - but this is typical being that it is newer. I got it in black and like the contrast of some of the silver buttons on it. Also the back button is located more properly in my option and has a more satifying press.
The sound is very similar but I find the zip sounding a little brighter which I happen to prefer on my UM3Xs.
Overall I love them both but the zip is a little more rich of an experience with a colored screen. Also it runs doom great and the spectrogram is super cool.
As always for me - both are rock boxed. Hate the stock UI.
One last thing the Clip Zip has a micro USB port... Not a mini USB port like that of the sansa, I like this so much better. Everything uses micro USB now, i never understood why the clip + used a Mini. Now I can plug my sansa into pretty much any power adapter I have.
It is already a blessing they decided to use mini usb instead of a proprietary charger connector.
Which version of RockBox is best to use on it?
Whats up with the buzzing sound when changing tracks, and sometimes mid track too..? It's not present in stock firmware.
