Interesting last post by MilesR especially considering the following post that I was in the middle of drafting.
I recently downloaded the latest Lurker updated Mango firmware with loader and rockbox (dual boot) from Napka’s site here:
http://napych.com/other/rockbox-for-ibasso-dx90/official-rockbox-binary-builds/ . I may be missing something but RB isn't doing it for me at the moment and I prefer the modified Lurker Mango interface under the dual boot loader option, as it is uncluttered, simple and what I was used to with the i basso stock firmware.
My initial thoughts on RB in particular after trying it for a while are as follows:
So many RB menus! Not sure I really need them and getting used to navigation has taken a while but I am getting there. I still need to read the RB manual though and appreciate that it has many impressive override options and could be attractive if certain IEM’s are used etc. where controls such as bass etc. need to be boosted.
RB has resolved the intermittent gapless problems I was having with the version 2.3 stock firmware. However, the modified Mango firmware from Napka also seems to have resolved this so I'm really happy.
The RB battery indicator still seems misleading, following earlier posts I have read on this thread. I can live with this though, although it excited me when RB first suggested I had over 9 hours! i basso suggest 8 hours in their manual but I have hardly been getting 6 hours so far with FLAC with the stock battery which is really disappointing.
Biggest struggle was understanding the volume scale in RB. I really like the simple appearance of the volume dial in Mango and how it increases from zero to 255 (easy). The RB volume scale seems to work in the opposite direction and between -255 and -100 the scale is measured only with two digit numbers which doesn't seem very user friendly. The loudest level is 0 and the minimum volume is -255, which took a bit of time to work out. Also RB seems quite a bit quieter than Mango at the moment (might be a tweak in the settings somewhere that I haven’t found?) because I only get a reasonably good volume at approximately -51, compared to a similar volume at around 182 on Mango. i.e. seems more headroom in the Mango volume range. Despite this, even in Mango (stock version and Napka’s modified version 2.30 + L1) most of my FLAC files still need to be played above 180 to get a reasonable volume (unless it is a very good original source recording). The volume only seems to really kick in above 100-120 and it seems that the first 90 or so steps even on the Mango volume scale are virtually silent on most cd FLAC rips and below this (on average) I can virtually hear nothing. Do other people find this? Perhaps this is just a design characteristic but then what are the first 100 or so steps there for if they don't produce a decent listenable volume? This review seems to back this up:
http://headfonics.com/2014/07/the-dx90-by-ibasso/5/ and indicates that for a range of IEM’s, the volume was at around 195-200, leaving only 55 more step ups available to the maximum of 255 (which I accept should be more than loud enough). I am currently using Shure SE535 IEM's.
