Rockbox for iBasso DX50 dual boot with stock firmware
Mar 16, 2015 at 9:40 PM Post #1,666 of 2,020
Hi all.  Long time lurker, but I joined because I am having trouble installing Rockbox in my DX50.  I have extracted the contents of the .rockbox zip directly into the root directory of the DX50 itself, and have tried putting the update file (downloaded from the link on this thread) in both the root of the microSD card and the root of the DX50 to no avail.  It says that it can't find the file/image.
The microSD card is exFAT formatted (it is a Delkin 64gb card).  It is the only microSD card I have, and is almost completely filled with music so I don't want to reformat it to FAT32.  I see in the install instructions that the card may have to be FAT32.  Should I get another, small/cheap card to format as a FAT32 to do the install, or is there something else I can do?
Thanks!
Mar 16, 2015 at 10:38 PM Post #1,667 of 2,020
Thanks!
If you are using recovery to update then the SD has to be formatted with fat32.
Mar 23, 2015 at 5:10 AM Post #1,672 of 2,020
I've compiled the latest git source with modern_ui and user selectable hold switch mode. I've made it by typing in terminal:
ANDROID_NDK_PATH=/path_to_android-ndk /path_to_rockbox_source/tools/configure --target=ibassodx50 --type=n && make zip
The source compiled and there was a zip file containing the firmware. It was working on the DX50, but some options were missing. For instance no USB mode menu. After plugging in the USB cable there was an error message saying that the rockbox folder is missing but it wasn't. What am I doing wrong?
My build environment is Mac OS X 10.8.5 + command line tools + git from homebrew + latest Android NDK
Mar 23, 2015 at 6:21 AM Post #1,674 of 2,020
I used FW 1.8.0 with dualboot app. Normally the USB settings are in Settings -> General settings -> System -> USB Mode. There was also no cpufreq governor menu, HAAS Surround, Auditory Fatigue Reduction, DAC Filter Roll-off and many things. Maybe I did something wrong with git? I used these commands:
git clone git://git.rockbox.org/rockbox
cd rockbox
git fetch git://git.rockbox.org/rockbox refs/changes/75/1075/13 && git checkout FETCH_HEAD
git fetch git://git.rockbox.org/rockbox refs/changes/07/1007/10 && git checkout FETCH_HEAD
cd ..
Then I renamed rockbox folder to rockbox-git and started building.
Mar 23, 2015 at 8:50 AM Post #1,676 of 2,020
  sorry, I'm not a gerrit and git specialist. The difference I did was to do cherry-pick instead of checkout
Could you tell me how were you using cherry-pick command?
Mar 23, 2015 at 3:29 PM Post #1,678 of 2,020
Thanks! I've finally made it
Here's the build if someone is interested:
https://www.sendspace.com/file/14c0mb
Mar 24, 2015 at 7:04 PM Post #1,679 of 2,020
Last year I installed Rockbox on my DX50 and I couldn't find my music so tried for ages to get it uninstalled. Have just re-installed it and managed to find my music and oh my how great is the sound quality. It is amazing. Don't think I'll be using Mango anymore.
