R-Audiohead
- Dec 4, 2010
We all know "new" or "upgraded" doesn't always mean better.
Also, does that mean most of us own a "D100 Mark I"
Can anyone tell me if this DAC would be a good option to pair with a tube amp, the Little Dot MKIII?
Thanks.
Unless I am mistaken, the Yulong joins the Cambridge Audio DacMagi Plus as the only budget, multi-featured digital pre-amplifiers featuring variable XLR output.
Sorry, but the D100 is not variable on the output (except for headphone amp section). The line out for both RCA and XLR is fixed volume.
So, the mailman just delivered my D100 an hour or so ago.
I was actually going to get the TubeDAC-11 suggested to me by Project86, but as I was searching on eBay I noticed a local seller with a used D100 for sale at a relatively cheap price, so I figured I might as well try it out.
I found an old adapter and plugged in my JH16s. It all sounded pretty sweet untill 2 minutes in when it suddenly jumped ALOT in volume and more or less killed my ears, then it started with that scratchy sound that you got on old TV's when nothing was on at night. Then it returned to low volume, and the process started all over.
I've tried both the "Low" and "High" headphone sockets as well as trying with 2 different adapters.
Any clues as to what could be wrong? It's plugged in via USB.
Additional info: Using an onboard soundcard at 2% or so volume and the D100 at 1-2 ticks above zero. (Seems I should be able to control the volume better than this, but it goes loud really fast?)
My motherboard is a Gigabyte 55A-UD3, not sure about the "sound card".
Does the Mk II version have variable level analog line output over XLR?
Working just fine with my MBP, so it's definitely the other computer that's acting up. Any and all info and suggestions are appreciated.
