project86
- Feb 21, 2007
My D100 has excellent channel balance, even using very sensitive IEMs at low volumes. I think it is just luck of the draw though as I've had issues with low level balance on several fairly expensive amps... I bet if you took a dozen of the same model of potentiometer, some of them would be perfect and others would have varying degrees of imbalance.
As for the knob making a "rubbing" sound: I bet it has a slight imperfection in shape and is thus dragging against the case at certain points in the rotation. Try pulling it gently and see if it slides out enough to fix the problem. I don't see a screw holding it on so I bet it is the type that just slips on and stays due to pressure. Even if you pull it all the way off it shouldn't damage anything, and you could just push it right back on.
