K240 DF is now discontinued, specs were 600 Ohms and 88db SPL/mW it's not the kind of headphones which cost 300 USD... 100 or 120 USD on ebay maximum, but not more...
For 300 USD i'd look for an AKG K601 (sound is neutral, but theses headphones aren't very famous here, i don't know why i fount them better than K701, try to read some reviews).
I know that the K240 DF is a vintage headphone, that one can only get through ebay or used.
I have read very good things about it, but I'm still unsure if it's sound quality is at the level of the K701 or the Sennheiser HD600...
I would like project86 to give his honest opinion about this. And by the way which of these three is the most transparent and accurate?
I'm shure that the K601 is a great headphone, but the reason why the German Maestro GMP 450 Pro is one of my options is precisely because it has been compared favorably to the K701, DT 880 and other high end headphones and it is said to be more transparent and accurate, while being also highly musical. I also remember that it's predecessor, the MB Quart QP 450 Pro, was compared the same way to the K601 and the results were the same.
The GMP 450 Pro (2*300 Ohms) has also the advantage of being easier to drive than any of those AKGs, it can be driven by portable sources. So the Yulong D100 would drive it better.
Thanks for your suggestion anyway, cheaphifi!
The German Maestro brand isn't a very well known, but it's headphones are acknowledged to be highly accurate.
What I want above all from my system is Transparency and Accuracy. The most transparent headphone I can get for 230 Euros would theoretically be the best match for the Yulong D100 in that regard.
After, at least, one year of search all over the net for the most transparent and accurate headphone,within my budget, with which music actually sounds like music, and that doesn't require a mod to achieve so, the German Maestro GMP 450 Pro is what I found the best... but on the last days I caught the AKG K240 DF, thanks to some helpfull headfiers, and I have been reading very good things about it.
But I still have some doubts regarding the K240 DF's sound quality:
Is it's overall sound quality comparable to the K701, HD600 or DT990?
Is it more transparent and accurate than those?
project86 has the answers! Please write a mini comparison between these cans and the K240 DF so that you save my day!
I don't want to be to demanding so that will be my only requirement!
Thanks!
Oh, by the way, project86, when are you going to write your review of the GMP 450 Pro?
