Now I discovered another useful feature of Central Station.
There is an AUX input with RCA jack, and it has an active volume control in the input stage, before it enters headphone amp or preamp section. I normally don't use this because the signal passes through two volume control stages--on the front plate you can see an AUX volume pot only for this input.
Today I actually listened carefully to AUX input to see if the extra active volume control degrades the sound. My SACD/DVD player's two RCA outs are connected to TRS2 and AUX inputs, and level matched. Listening through built-in amp or external amp via passive preamp out, I think the difference is really minimal. I could tell a slight difference but could not really pinpoint which is better. I now accept that the AUX input is sonically robust.
The AUX input becomes really handy when listening to the analog out of my SACD/DVD player (2V output). At this output voltage, the internal amp can't dirve K1000 loud enough. Once I jack up the AUX level knob to match DAC1's 22V XLR input, the headphone amp drives K1000 just fine. I listened to Pink Floyd's DSOTM SACD and it sounds pretty exciting, with all the spooky effects intact.
In short, Central Station's headphone amp is fully functional with K1000. With high level inputs near 20V, it can work very well. With normal level inputs around 2V, simply use AUX volume knob to ramp it up. AUX knob at 1 o'clock position makes 2V input as loud as 22V input (while headphone volume at 10 o'clcok to drive K1000). At this knob position, there is still plenty of headroom. After this amplification, the internal amp again drives K1000 very well. Throuhg AUX input, it can be thought of a two-stage amplification to drive K1000, kind of like preamp/power amp for speakers. This quite legitimate since K1000 is a earspeaker to begin with. My headphone tube amp uses three stages (12AX7, 12AU7 and EL84) to drive K1000.
Previously I was in some kind of jazz slump for months and months, as jazz all of a sudden stopped sounding exciting to me (can't get that swing). Since a few days ago, as I started driving K1000 with Cnetral Station, my jazz passion is revived. Listening to "Friday Night in San Francisco," I could swear these three guitarists were on fire (McLaughlin, di Dimeola, de Lucia).
