music_man
- Jun 6, 2005
when i said "clinical", i was indeed using audiophile speak as to mean "true to the source". i used that word since this is not a pro audio forum. it may better convey what i hear in the cs to most of this forums members.
that is not meant to belittle anyone here. simply, audiophiles have one set of language and engineers another.
i think one can safely say that the cs is among the top solid state equipment currently available. that is, if one is looking for uncolored sound. many audiophiles indeed are not. when we compare the cs to other top da converters and headamps we are comparing nuances. it is mostly agreed that it is in the top tier of equipment in this category. many of you that own it have not even realised it's preamp yet.
when one considers the price of this unit amazement comes to mind.
some things are said to be just ok, but become great because of their price. in those items the limitations are overlooked due to it's price. this is not true at all of the cs. i hope presonus is not reading this because i think they would have people buying this if it was $2,000. it is company with the grace and dac-1 , and then there is the preamp. if you think the dac and head amp are excellent you will be floored by the preamp. if you need that function it's there.
freefilter, yes i do think multiples of 44.1khz are preferential. aka oversampling. i am not so fond of upsampling. no one listens to me about that though. however, if you do upsample it is easier on the oversampler since less of the brickwall filter needs to be employed. it moves the noise into a higher domain allowing the oversampler more headroom. this is theoretical of course. my preferance remains to use only oversampling. which the cs already does. i think the key is in feeding it very low jitter. in that respect i use a mark levinson transport and a 1 meter very exquisite cable. i figure you already know about oversampling vs. upsampling. i am mentioning this as it applies to the cs since you asked. i found that a superior transport operating at 16/44.1 easily bested a lesser transport at 24/192 when feeding the cs.
the issue is that i personally feel that there is not an upsampling transport made that can equal the old mark levinson unit. even if the ml is operating at redbook standard. therefore i do not intend to try other transports at this point. hopefully you will and let us know. or use a computer.
keep in mind that depending on what computer hardware you have, higher sampling rates may render poor results. doing that on a pc takes serious power to be implemented properly. it should be done by a sound "sub system" such as amp-farm and not by the pc's cpu.
you can achieve the same results with a computer as you would with a high end transport of course. it shall be equally expensive to do so.
music_man
music_man
