Bruce, good to see you here!
Have you had a read of twisters review of the Cayin N5, I think he might compare it to the A100. (I will read it soon)
His link is over on the lab thread.
Thanks!
No I haven't read it but I will. Thanks.
I'm not sure how much support the AP100 will get from now on. It seems they are all busying working on the AP300, and to be fair they have done lots and lots since the original firmware.
If you buy an AP100 now it is better to go in with expectations that it is as is and not being overly hopeful for future firmware releases.
So : exactly the same bug in NTFS. 5800 files and the scan stop ! :-/
@hidizs did you try to update the library with more than 5800 files into one of your AP100 with microSD card formated in NTFS ??
(5.800 files limitations and 128 Go support, hum hum...)
I can have more than 5800 , but the scan for "tagging" stop at 5800 files. All the files after that are not in the tags folder : Artists, albums,...you only can see it in the folders library, not by tags. :-/
@raiderkilo : give a try, see if your last Artists are in the "artist" tag library. And please give a look at your scan when you are doing it : the number increase after 5800 or the count stop to thus number?? Thanks.
@BruceMatter : I try with ntfs because Hidizs said that it is a formatting bug with my micro-sd card and it could be better in ntfs. But no effect. I come back to fat32,same limitation with the twot formats!
Guys, my review of the AP100 is up, have a peek you might discover a few new things you didn't know about
http://www.head-fi.org/products/hidizs-ap100-portable-hifi-audio-player/reviews/14095
Cheers,
Bruce
