Dsnuts
- Jun 20, 2011
Fiio X5iii
bought im03 recently. any recommendations on dap to pair with this iem?
If you are on budget, xduoo x10. great sound (bass tad a little weak) and it doesn't have much/any features though.
currently im using lotoo paw 5000 and it got hiss
I also bought the 1More Triple Driver recently..... the E40 also has better sub-bass extension.
Hi everyone,
I really like the ATH-IM02 but with the stock tips or Spinfits it doesn't isolate enough for using outdoors and in the subway. When I try with the included Comply tips, the sound gets drastically muffled. Does anyone also experience this? I have used Comply foams and Shure olives with other IEM's like Shure and Westone and that did not happen. If you've experienced this, did you solve it somehow?
Thanks!
Does anyone know of an online store that sells quality braided cables for the ATH-IM series and ships to Europe? I find the stock cable too microphonic with the tips I'm using.
Thanks.
I had the same issue, and never ended up finding one. I looked at the ones from lunashops, but heard that the quality was poor and the shipping long
the housing connector for my im03 broken cos im stupid. is it possible to change to mmcx?
