I hear you Twinster.
That's the appeal for me, too - it's size and ability to be used portably - as a source for the DACmini in a transportable rig - per the photo, above.
I found this very positive review of the Squeezebox Touch, but it left me confused:
http://www.computeraudiophile.com/content/Logitech-Squeezebox-Touch-Review
On the one hand, the reviewer writes:
But later in the article, he writes:
The way it reads, I might not even notice any "dullness," but it's hard to quantify just how bad it is, reading this. It seems you are quite pleased with yours, given that you use it as part of your living-room rig, so I'm still intrigued.
I, personally, don't have a problem with the fact that it has a plastic case - I'm after function and if the Squeezebox Touch + DACmini can compete with a small netbook or laptop + DACmini - for sound quality - I'd be content.
Question: Have you ever tried connecting the DACmini to the SB Touch using USB interface (instead of coaxial or toslink)?
I ask, because I'm also kicking around the idea of using the SB Touch with a Centrance DACport LX + Meier Stepdance. I don't know if the SB Touch has enough power to supply the DACport LX, though - even if it could be connected to a DACmini via USB.
Another question: Assuming I go with a DACmini via coaxial connection, do you know of the SB Touch can power a small USB hard drive (not a flash drive, but a 2.5-inch form factor hard drive that normally gets its power - and data - from a laptop or desktop PC's USB jack.)
Anyone else have any suggestions for a small, lightweight, battery operated source for use with the DACmini or DACport LX?
Thanks again!
Mike
