piotrekfronc
- Jun 3, 2013
I ve one but I wont sell I for less than 10000 USD (im serious)
It's a that good. Alex mod + 3 amps an 4 b sets.
Correct ~300 we're produced. 45 of them were modded. There were 2 balanced card - standard and golden (with better operational amplifiers)I heard only ~300 pcs of these were made.
I wonder if anyone here has Golden Card for MA9 - apparently they never made it to serial manufacturing.
Unfortunately I was able to get the standard one only, but considering they are not in production any more, I'm feeling like I got a deal.Black Gate Golden Card sounds so much better than standard or regular balanced.
What firmware do you use? stock or rockbox?Guys, I need help. I have a semi-broken MA9. It should be in working order but somehow it stops playing music after 5 minutes and there is only hum... resetting doesn't help. Tried to switch software versions to no avail, on some versions I get 5 minutes of music (or not) and then it breaks and there is only hum / noise. It's a new unit for me bought from a friend here on head-fi. Could you please help me get it in working order?
Is the unit fully charged? If one of the batteries is very low, it may cause a shutdown.Guys, I need help. I have a semi-broken MA9. It should be in working order but somehow it stops playing music after 5 minutes and there is only hum... resetting doesn't help. Tried to switch software versions to no avail, on some versions I get 5 minutes of music (or not) and then it breaks and there is only hum / noise. It's a new unit for me bought from a friend here on head-fi. Could you please help me get it in working order?
I've used various Rockbox builds. Maybe I could test stock? Can you provide me with files?What firmware do you use? stock or rockbox?
What file format you're playing when having that issue?
Yeah, one rockbox build shown me one of batteries was down (other builds didn't!) and it shut down the device. So I charged it. And other build weren't shutting down the device. That makes me think maybe one of the batteries is broken?Is the unit fully charged? If one of the batteries is very low, it may cause a shutdown.
