So here's the question. Why has no one tried modifying T50s to true open back running? The driver definitely doesn't like being enclosed in a cheap, microphonic plastic canister and, if the diaphragm is doing as it's told by the signal, the cans ought to sound reasonably in the Electrostatic league.
Wow, my thread's still bumping after all these years?
Well, I had to bring in an update based on this post. Though, rather late with a poster who's probably far gone.
I've been modding my T50RP steadily for the last couple years, and I've found the niche that I like from them.
Here's my findings:
- Pads matter the most. Period. In the Fostex T50RP Incremental Mods and Measurements thread, pads make far more of a difference than any other mod you can find.
So, I've made micro-velour pads with memory foam. Not "cut to shape" memory foam, but memory foam that I've shredded into fluff to make it much lighter and softer. This creates a similar seal to pleather/leather pads without the sweating. The pads are still very deep and seal well--which is key.
- While dampening and closing the back of the drivers matters a lot to flatten the frequency response, I find the sound to be really "closed" and canned. The soundstage is small, bass doesn't sound natural, mids feel more forward, and highs can sound tinny. I can't stand this sound with these drivers. Like, with my MDR-V6, I'm fine with the limited (yet good positioning) of the soundstage. But, not with the T50RPs.
What I've done is make them far more open. I've pulled the tape off the back of the vents, and have taken a knife to the permanently closed vents to even open up the back more. I find this to massively open up the sound stage and still provide more than enough bass for my needs (they certainly aren't bass-light, but a bit over neutral). With this, I've left the backing of the drivers all the way off without any tape or sealer.
I'm unsure at this moment if it's the openness, or the bass reflex of limiting air movement through the back of the headphone. I want to really plant these drivers in a wide-open back (like LCD2, HiFiman) with a tilt in both the driver and the pads to test this out.
With my current mods, the sound isn't perfectly flat and the bass doesn't reach down the lowest, but it's a lush sound that I haven't found any other can to produce. It's why they've been my daily drivers for the last couple years and I still have my second pair hidden away in a cabinet just in case.
