BotByte
- Dec 14, 2010
All parts of the spectrum improve by removing the white felt and replacing it with a stiff craft felt... this requires tuning the vent to reduce the then huge bass output, but it works incredibly well. My $.02 is this will take your mod even further, but the caveat is it is not reversible. I have built 5 pair and done significant A/B time, and there is no comparison.
Also, BluTak can be improved on by using plasticine. It is way denser and better at mass loading the baffle and killing resonances in the plastic.
I'm curious why you chose to damp the back cup with blutak instead of using foam to kill reflections. Did you A/B? What was the result? Or have you only tried it this way?
Loved the hand-made ear pads and band. Wish I could sew leather (probably just need to try and be willing to thread my finger a few times)...
I used the blutak because when I used the felt, things started to get muddy. I've tried well over two dozen setups and found the one that worked the best.
The leather needles are sharp. I've sent the entire needle through my finger and out my nail before. Maybe it wasn't smart to sharpen them any further.
Maybe I need to do a step by step tutorial here.
Also, I'm thinking of adding foam (not felt) to dampen the driver.
I also don't believe in the clarity of screens. It's placebo. I've only cut the inner felt of the cups off. I'm not touching the drivers.
I'll compare mine with the one that's being shipped to me at the moment. See how it is vs. stock.
