mythless
- Sep 19, 2009
Everything is so confusing!
Haha, if it wasn't, it wouldn't be as fun, though it is a bit torturous in trying to decide what to buy.
BTW ClieOS, since you've tested out a lot of 'phones, I was wondering if you've tried Panasonic's RP-HJE900. If you have, can you give a comparison of the RP-HJE900 and the DBA-02? For that matter, if anyone has them both, or have tried them both, please feel free to offer your input.
Mainly what made me interested in the CK10s is when someone says it has a more "clear" bass than the DBAs. I listen to jazz and classical primarily, and hearing exactly what is happening in the lower spectrum is important. So is having well done cymbals and highhats...I really like how the RE0s handle them.
However, I've A/B'd the RE0s with my K701s and noticed that there's a "blur of notes" on some tracks (with the upright bass) that I can hear crystal clear with the K701s. If the DBAs are more along the lines of my K701s then I'll be happy..
When you say "more bass" - is it a clear bass? And does "more musical" mean less analytical?
I had the same question, which h20buzz answered very nicely back in post #563. I won't try to summarize.
I am VERY satisfied with the DBA's and am now considering how I'd like to back them up - a second set of DBA-02's, HJE900's (with Comply tips as h20buzz recommends), or something like the recent Hippo Shroom EB's for much less.
Having owned both (I paid $199 for the CK10s) I would rather have the DBAs, mainly because they do deliver a little more bass and also are much more comfortable for me. Main reason I sold the CK10s was a comfort issue. Oddly, the CK10s with the triple flanges were not comfy, but the DBAs are. Go figure. I also have the option to use my UM56 custom sleeves with the DBAs, which I do on occasion.
No doubt the CK10s are built better than the DBAs, but given the choice, which I did have, I chose the DBAs. I would not call the CK10s a step up, but that's my view. The DBAs are more musical to me than the CK10s. Joker may feel differently, because he has both the CK10s and the DBAs (borrowed a pair for review purposes).
... my will power is pretty weak.
...not much damage to your wallet.
When you have bought things at like $300 (e-Q7) and then something at $160 it's not so bad I bet buying these will be better than buying that HF2 you have in terms of price
Or when you buy something worth $1,000+ and then something worth $160....it's not that bad. Oh the sacrifices we make to inform you guys.
The DBA-02 just kicks serious butt!
