mrarroyo
- Jul 27, 2005
Many of the amps listed are good alternatives, some work better with a particular headphone than another. Ideally you should attend a meet to hear for yourself with your cans and music which one you prefer within your budget.
I will throw on the mix an old amp which I still love and which IMO sounds superb w/ a few simple and inexpensive mods. The Musical Fidelity X-Can V2, it can be bought used from $140 to $170 w/ S&H. Then spend an extra $100 to perform the PinkFloyd Mods and finally go to Jameco to purchase their 1.5 amp PSU ( Jameco Electronics ICs & Semiconductors: JAMECO RELIAPRO : ADU120150E1012 ) to replace the 0.5 amp PSU supplied by Musical Fidelity.
I owned the K701 and currently own a Senn HD580, and a couple of Grado cans. All are driven superbly by the modded X-Can V2. Note an X-Can V3 would also work fine but you would need a different PSU than the one I listed above.
