Brown Cow
- Aug 6, 2004
My px100's outdo them both
Originally Posted by stevieo the k1000's are tops! why don't they get more respect? |
Originally Posted by gsferrari I agree that they are sensational headphones. But not too many people can fork out $700.00 for a pair. Also - finding the right amplifier is an ordeal. Why? Here's why :- . |
Originally Posted by stevieo no argument here. i'm just a step ahead of the collection agent myself |
Originally Posted by gsferrari The risk of picking the wrong amp for the K1000 is quite real and that is what , I think, keeps people out of K1000 ownership. Flecom (from the recent headfi meet) is VERy happy with the K1000 he picked up there...and guess what...he is powering it out of the same amp Gene picked up (the $30.00 affair). It also worked well out of the PIMETA he had at the meet |
Originally Posted by gsferrari I would love to have a k1000 and an amp and actually came VERY close to buying mikeg's monoblocks. But a quick audition between HD-650 + Rudistor RP5 and the K1000 + monoblocks (ASL Wav 8 I think) and even the K1000 + ASL AQ005DT (??) proved that the HD-650 + Rudistor was a superior combo for most genres of music. |
Originally Posted by mikeg Guru, when you heard my K1000 driven by the ASL AQ-1005DT power amp., this amp was controlled by an ASL Passive T2 passive preamp. What I've been trying to let people know is that use of my SinglePower SDS amp as a powered preamp for driving the AQ-1005DT gives a totally different result. The K1000, when driven by the combination of ASL AQ-1005DT/SinglePower SDS units, sounds far superior to the way it sounded when driven by the Passive T2 unit. Anyway, you should (and will) hear it soon. |
Originally Posted by jpelg Mike, What I am wondering is what exactly the Supra is doing in that chain to improve things so dramatically now? Is it the additional amplification of the signal that is improving things so much over your former passive preamp? What is the line-level output of your source? Or is it that the Supra is altering the sound characteristics so that you now prefer the result? If it is the latter, then couldn't one potentially achieve the same (or better?) result by rolling tubes in the main amplifier? Shorter/simpler pathway, and all. What 300b's are you using? What other tubes are in the AQ-1005DT that could be rolled? What IC's are you using in between to two amps? Btw, I don't dispute your findings, nor the fact that the K1000's are a stellar headphone. Just curious. |
Originally Posted by sacd lover Hey mikeg, did the ps audio ultimate outlet have minimal negative impact on the Supra's sound quality? I know you were dissatisfied with your power conditioning before and liked the amp best straight from the wall. |
mikeg said:When I first encountered the improvement of using the SDS as powered preamp, I contacted Mikhail and asked for his opinion. From what I recall, his explanation was that the improvement in base, clarity, fullness, etc., were to be fully expected contributions of the SDS unit. As I understood Mikhail's explantion, the fine qualities of the SDS that accrue to any headphone that's connected directly to it, are also "passed through" to units connected to it, when it's used at the preamp. that drives these units. I should add that the Passive preamp. that I previously used (i.e., the ASL Passive T2) is really a high quality one, and yet, it's performance does not match what I get by using the SDS as powered preamp.
Mikeg, would you say that it's the SDS that's really making the difference in what you're hearing and if it were possible to use the SDS as direct amplification to the K1 you might get the same results?
As I understood Mikhail's explantion, the fine qualities of the SDS that accrue to any headphone that's connected directly to it, are also "passed through" to units connected to it, when it's used at the preamp. that drives these units. |
